Zum Hauptinhalt wechseln
Toshiba Satellite C50-B-14Z Thermal Pad Replacement
  1. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Opening the laptop.: Schritt 1, Bild 1 von 2 Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Opening the laptop.: Schritt 1, Bild 2 von 2
    • Unscrew the 15 screws holding the back panel in place.
    • Use a prying tool to carefully release all the clips.
  2. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Changing the thermal pad.: Schritt 2, Bild 1 von 2 Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Changing the thermal pad.: Schritt 2, Bild 2 von 2
    • Unscrew the 4 screws holding the CPU heatsink and fan assembly and lift it up, gently.
    • Disconnect the fan.
    • Replace the thermal pad. Be sure to use the same thickness thermal pad.
  3. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Cleaning the fan.: Schritt 3, Bild 1 von 1
    • Unscrew the 2 tiny screws that hold the fan assembly together.
    • Clean it with a soft brush and compressed air.
  4. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Upgrading the RAM and SSD (Optional): Schritt 4, Bild 1 von 1
    • Once you opened the back cover, it is a good idea to upgrade the SSD and RAM if you want.
    • This model can take up to 8GB DDR3L.
    • You can also put in a CD/DVD Drive or an additional SSD in its place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Simeon Brankov
6.094 Reputation
51 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 265
