Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  2. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  3. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: Schritt 3, Bild 2 von 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  4. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: Schritt 4, Bild 1 von 2 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: Schritt 4, Bild 2 von 2
    • Unscrew all 15 of the screws in the back cover of the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  5. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the two silver screws attaching the fan to the case.
    • Unplug the power connector for the fan.
    • Pull the fan up out of the slot.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Rei Rutkowski
184 Reputation
2 Anleitungen geschrieben
IUPUI, Team S8-G8, Wilson Fall 2018 Mitglied von IUPUI, Team S8-G8, Wilson Fall 2018
IUPUI-WILSON-F18S8G8
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
The one I disassembled didn’t have a screw under the battery bay, but did have one under the HDD bay, just as described by a comment in the charge port replacement guide.
Luis Alejandro Araúz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 929
