Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5100 Charging Port Jack Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: Schritt 3, Bild 1 von 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: Schritt 3, Bild 2 von 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 5, Bild 1 von 1
    • Remove the disc drive from the device.
  6. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: Schritt 6, Bild 1 von 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: Schritt 6, Bild 2 von 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: Schritt 6, Bild 3 von 3
    • Place the laptop with the bottom facing up.
  7. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 7, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  8. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 8, Bild 2 von 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  9. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Charging Port Jack: Schritt 9, Bild 1 von 1
    • Unscrew all 15 screws that attach the back cover to the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  10. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 10, Bild 1 von 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 10, Bild 2 von 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: Schritt 10, Bild 3 von 3
    • Locate the charging jack. Then carefully pull straight up.
    • Unplug the connector by pulling it towards the charging port side of the case, then carefully guide the wires away from the case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rei Rutkowski
184 Reputation
2 Anleitungen geschrieben
IUPUI, Team S8-G8, Wilson Fall 2018 Mitglied von IUPUI, Team S8-G8, Wilson Fall 2018
IUPUI-WILSON-F18S8G8
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Hi. Correction on Step 9. Aside from the 15 black screws, I had to unscrew one silver screw. It sits right under the HDD.
Everything else was perfectly described.
Isidro B. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 1,431
