Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5100 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5100 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
  4. Toshiba Satellite C55-A5100 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Looking at the keyboard, locate the eight clips that hold it in place.
  5. Toshiba Satellite C55-A5100 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C55-A5100 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to slide the clips back, releasing the keyboard.
    • As you release the clips, use the plastic opening tool to lift keyboard above the clips.
  6. Toshiba Satellite C55-A5100 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • The keyboard will slide out of the clips on the top.
  7. Toshiba Satellite C55-A5100 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Using your fingers, slowly pull the wire out of its connection.
    • The keyboard is now disconnected.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 905
