Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5100 Optical Drive Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Optical Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the disc drive from the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 338
