Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5100 RAM Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5100 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 RAM Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Place the laptop with the bottom facing up.
    • Observe the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 RAM Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite C55-A5100 RAM Replacement: Schritt 4, Bild 2 von 2
    • Using your Phillips #1 screwdriver, unscrew the 6mm screw on the panel, exposing the hard drive and RAM.
  5. Toshiba Satellite C55-A5100 RAM Replacement: Schritt 5, Bild 1 von 1
    • Once the ram chip is exposed, push the two clips away from the ram chip to release it. (Clips move in direction of arrows.)
  6. Toshiba Satellite C55-A5100 RAM Replacement: Schritt 6, Bild 1 von 1
    • The ram chip will tilt up after the clips are released.
    • Using your fingers, pull the ram chip out at a slight angle.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 352
