Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5286 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5286 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Unplug the AC adapter and all other auxiliary components from the laptop.
  2. Toshiba Satellite C55-A5286 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • There is a removable panel on the underside of the laptop with one 5-mm screw holding it in place.
    • Use the screwdriver to remove the screw and then remove the back panel.
  3. Toshiba Satellite C55-A5286 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Underneath this panel is a silver square with rubber around the edges. This is the hard drive. On the side of the hard drive nearest to the manufacturer’s label, there is a large, flat 8-mm screw that is holding the hard drive in place.
    • Use the screwdriver to remove the screw.
  4. Toshiba Satellite C55-A5286 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Carefully hold the sides of the hard drive with the rubber and pull the hard drive out. It should remove fairly easily.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nicole Zellers
265 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G5, Hovde Fall 2018 Mitglied von IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
The hard drive is ‘encased’ in a foil-looking, very flexible ‘enclosure’.
On the screw-side (near the label), each corner of the foil enclosure has a rubber black stuffed between the drive and the laptop - these blocks are connected to the enclosure via a rubber ‘string’. If you pull those nubs straight up, you can pull on them towards the label to disengage the drive from its SATA interface.
William Totman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 799
