Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5300 Battery Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5300 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Battery Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite C55-A5300 Battery Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite C55-A5300 Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 402
