Einleitung
These are the steps for removing the battery from your Toshiba Satellite C55-B5302 laptop. Before starting, make sure you have your Phillips size #0 screwdriver and your laptop is not plugged in. If your battery is hot to the touch, wait until it has cooled down before removing it. Additionally, if the battery seems to be bulging or cracked, it should be disposed of properly and a not reinserted into your laptop. The battery is easy to remove and will only take you a few minutes.
Was du brauchst
Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
