Zum Hauptinhalt wechseln
Toshiba Satellite C55-C5240 RAM Replacement
Was du brauchst
  1. Toshiba Satellite C55-C5240  RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240  RAM Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite C55-C5240  RAM Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite C55-C5240  RAM Replacement: Schritt 2, Bild 3 von 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240  RAM Replacement, Back cover: Schritt 3, Bild 1 von 2 Toshiba Satellite C55-C5240  RAM Replacement, Back cover: Schritt 3, Bild 2 von 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240  RAM Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite C55-C5240  RAM Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite C55-C5240  RAM Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240  RAM Replacement, RAM: Schritt 5, Bild 1 von 3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: Schritt 5, Bild 2 von 3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • The RAM is at the upper middle area of the motherboard.
    • Push down on the clips on either side of the RAM stick evenly.
    • It will come loose in an angle once the clips are released.
  6. Toshiba Satellite C55-C5240  RAM Replacement: Schritt 6, Bild 1 von 1
    • Simply pull out the RAM stick.
    • These steps work for both sticks of RAM.
Abschluss
USF Tampa, Team S1-G5, Nance Spring 2017 Mitglied von USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 18
Insgesamt: 1,466
