Zum Hauptinhalt wechseln
Toshiba Satellite C55-C5240 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: Schritt 3, Bild 1 von 2 Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: Schritt 3, Bild 2 von 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Peel off the rubber hard drive mount.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G5, Nance Spring 2017 Mitglied von USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 1,672
