Zum Hauptinhalt wechseln
Toshiba Satellite C55D-A5108 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite C55D-A5108 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
Abschluss
Michael Medeiros
150 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 255
