Einleitung
Remove the RAM module with this guide. Reverse the steps to install a new one to allow for more laptop storage.
Was du brauchst
Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
With the Phillips #0 screwdriver, unscrew the 4.6mm screw on the left side of the "L"-shaped covering.
Push the two metal prongs on either side of the RAM module away from the module simultaneously.
Lift up the RAM module to remove.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
