Zum Hauptinhalt wechseln
Toshiba Satellite C55D-B5206 Trackpad Replacement
Was du brauchst
  1. Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 2, Bild 2 von 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Trackpad Replacement, Back Casing: Schritt 3, Bild 1 von 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 4, Bild 1 von 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 1
    • Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
  7. Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 7, Bild 1 von 1
    • Use a non-metallic object to lift up the gray ZIF tab on trackpad connector.
    • Gently pull the blue ribbon cable free.
  8. Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Use a small Philips screwdriver to remove the screw shown.
  9. Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 9, Bild 2 von 2
    • Push the two gray tabs out on the large wire plug shown.
    • The tabs only need to be pressed out a few millimeters, not all the way.
    • The plug can now be carefully pulled out.
  10. Toshiba Satellite C55D-B5206 Trackpad Replacement: Schritt 10, Bild 1 von 1
    • Gently lift the trackpad to remove it.
Abschluss
Elaine Butler
265 Reputation
2 Anleitungen geschrieben
IUPUI, Team 1-2, Beck Spring 2022 Mitglied von IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 143
