Zum Hauptinhalt wechseln
Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
Was du brauchst
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: Schritt 1, Bild 1 von 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: Schritt 1, Bild 2 von 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: Schritt 1, Bild 3 von 3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 3, Bild 2 von 2
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: Schritt 7, Bild 2 von 2
    • Pull the fan and heat sink away from the motherboard.
Abschluss
Laura Tamayo
678 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G4, Leahy Spring 2019 Mitglied von USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 339
