Zum Hauptinhalt wechseln
Toshiba Satellite C55Dt-A5306 Fan Replacement
Was du brauchst
  1. Toshiba Satellite C55Dt-A5306  Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306  Fan Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 5, Bild 1 von 1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306  Fan Replacement, Fan/Heatsink Replacement: Schritt 7, Bild 1 von 1
    • Using the Phillips Head #0 Screwdriver, unscrew four 3mm Phillips #0 screws, on the silver plate under the copper tubing.
  8. Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 8, Bild 1 von 1
    • Using the Phillips Head #0 Screwdriver, remove two 1.5mm Phillips #0 screw holding the fan down.
  9. Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 9, Bild 1 von 1
    • After unscrewing, remove the heatsink from the laptop.
  10. Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite C55Dt-A5306  Fan Replacement: Schritt 10, Bild 2 von 2
    • Unplug connected wire to remove the fan as indicated. Both the heatsink and fan should be removed before replacement.
Abschluss
Nahrain Putris
329 Reputation
3 Anleitungen geschrieben
Oakland University, Team 2-3, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-3, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G3
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 416
