Zum Hauptinhalt wechseln
Toshiba Satellite C55Dt-A5306 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • After removing the battery, open up your device so that the keyboard is facing you.
  4. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
  5. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Lift the old keyboard out of the way.
  6. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Before pulling out the keyboard, notice that it is connected to the motherboard via a ribbon cable. Gently press out the ribbon cable from its connection site and put the old keyboard aside.
  7. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
  8. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
  9. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
    • You can now remove the keyboard.
Abschluss
zeena qiryaqoz
301 Reputation
3 Anleitungen geschrieben
Oakland University, Team 2-3, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-3, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G3
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
mein keyboard war leider noch mit 2 schraubenähnlichen Arretierungen befestigt, und die Laschen an den Seiten ließen sich nur mit Gewalt aufbiegen, so daß das alte Keyboard jetzt im Unterblech ziemlich verbogen ist. C55Dt-A5306
immerich - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 711
