Zum Hauptinhalt wechseln
Toshiba Satellite C675-S7106 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite C675-S7106 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C675-S7106 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 2 Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Remove the lower-left plastic panel by loosening the single PH0-head screw and prying it up with a plastic spudger.
    • The screw does not need to be completely removed, as it's permanently attached to the device.
  4. Toshiba Satellite C675-S7106 Hard Drive Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite C675-S7106 Hard Drive Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite C675-S7106 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the existing drive by sliding it towards the left until it's disconnected, and then lift it out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dinis Valcorba
292 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 379
