Zum Hauptinhalt wechseln
Toshiba Satellite C675-S7106 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite C675-S7106 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite C675-S7106 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
Abschluss
Dinis Valcorba
292 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 461
