Zum Hauptinhalt wechseln
Toshiba Satellite C675-S7106 RAM Replacement
Was du brauchst
  1. Toshiba Satellite C675-S7106 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C675-S7106 RAM Replacement: Schritt 2, Bild 2 von 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Toshiba Satellite C675-S7106 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0 head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 RAM Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite C675-S7106 RAM Replacement: Schritt 4, Bild 2 von 2
    • Unclip and move the two metal clips on either side of one or either RAM stick.
    • Pull the stick outwards as you lift it upwards.
    • When reinstalling, ensure that the contacts are completely covered and connected.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 246
