Zum Hauptinhalt wechseln
Toshiba Satellite C855-S5115 Hard Disk Drive Replacement
Was du brauchst
  1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 2, Bild 1 von 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 4, Bild 3 von 3
    • Pry the back panel out of the laptop using the spudger tool
  5. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 5, Bild 2 von 2
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  6. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 6, Bild 2 von 2
    • Slide the HDD towards the sticker on the left.
  7. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 1,333
