Zum Hauptinhalt wechseln
Toshiba Satellite C855-S5115 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite C855-S5115 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C855-S5115 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Pull out the connector attaching the keyboard to the main body of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Antwort
Do you have to do anything with the connector before removing?
William - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 21
Insgesamt: 2,563
