Zum Hauptinhalt wechseln
Toshiba Satellite C855D-S5109 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite C855D-S5109 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite C855D-S5109 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Toshiba Satellite C855D-S5109 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Using a Jimmy, slowly lift the keyboard up and away from the palm-rest. Slowly work around the edges, pushing the clips back, prying the keyboard up with minimal force.
    • Be sure to place the tool under the keyboard not the keys themselves!
    • Patience is key on this step; it might take a while, but don't force anything or you'll risk breaking a clip.
  5. Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite C855D-S5109 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Flip up the locking flap of the ZIF connector holding the keyboard cable on the motherboard.
    • Pull the keyboard ribbon cable out from the connector on the motherboard.
    • The ribbon should detach from the palm-rest not the underside of the keyboard.
    • Remove the keyboard from the laptop.
    • While replacing the keyboard, you will not need the Jimmy. Just gently press down around the edges of the new keyboard after plugging the ribbon cable in. You will hear it click back into place as the clips engage.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Casper College, Team 1-3, Lareau Fall 2021 Mitglied von Casper College, Team 1-3, Lareau Fall 2021
CASC-LAREAU-F21S1G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 258
