Zum Hauptinhalt wechseln
Toshiba Satellite C855D-S5303 Disc Drive Replacement
Was du brauchst
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: Schritt 1, Bild 1 von 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: Schritt 1, Bild 2 von 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: Schritt 1, Bild 3 von 3
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: Schritt 2, Bild 1 von 1
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite C855D-S5303 Disc Drive Replacement: Schritt 3, Bild 2 von 2
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 360
