Einleitung
This guide will show you how to remove your laptops hard drive. This process requires a small Phillips Head screwdriver and your hands. There will be several small screws removed, so be sure you have a place to store them as you work to keep from losing any.
Was du brauchst
Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
Once the screw is removed, pry the panel upwards by gripping the groove pictured.
Locate the hard drive. It is in a metal casing as pictured.
To remove, grab the right side of the piece and slide leftwards.
Lift up and out.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
