Zum Hauptinhalt wechseln
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
Was du brauchst
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 5, Bild 1 von 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 6, Bild 1 von 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: Schritt 7, Bild 1 von 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: Schritt 7, Bild 2 von 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: Schritt 7, Bild 3 von 3
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 9, Bild 2 von 2
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 10, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 11, Bild 1 von 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 11, Bild 2 von 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: Schritt 11, Bild 3 von 3
    • Open the laptop and remove the display assembly from the keyboard assembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Matthew Hook
439 Reputation
4 Anleitungen geschrieben
IUPUI, Team S1-G6, Hovde Fall 2019 Mitglied von IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 289
