Zum Hauptinhalt wechseln
Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement
Was du brauchst
  1. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement, Screen: Schritt 1, Bild 1 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement, Screen: Schritt 1, Bild 2 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement, Screen: Schritt 1, Bild 3 von 3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Your screen is now completely detached from the internal components.
  5. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the copper shield by removing the four Phillips screws that hold the shield in place.
  6. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Unplug the battery from the motherboard by pushing the white clip with a metal spudger. You can attempt to use the plastic spudger first, but it may be more difficult.
  7. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove 2 6mm Phillips #0 screws holding the battery in place.
  8. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery by lifting on the left side, while holding the ribbon cable above it out of the way.
  9. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Use a size 0 Phillips head screwdriver to remove the 4mm screw which secures the Wifi Card in place.
    • Make sure to carefully remove Wifi card from the motherboard to prevent damage.
  10. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 10, Bild 1 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 10, Bild 2 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Remove the middle, top left, and bottom left 4mm screws from the motherboard using the size 0 Phillips screwdriver.
    • These screws are identified by a solid gold ring around the base of the screw on the motherboard.
  11. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 11, Bild 1 von 2 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Proceed taking off 2 additional 4mm Phillips head screws identified by the gold ring.
    • These screws are located on the top right and bottom right corners of the motherboard.
  12. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 12, Bild 1 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 12, Bild 2 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 12, Bild 3 von 3
    Kaufen
    • The next step is to carefully remove the small 3 pin connector using tweezers.
    • There are two of these 3 pin connectors, located on the top right and top left regions of the motherboard.
  13. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Located on the top middle region of the motherboard, the ribbon cable connector must be disconnected in order to replace the circuit board.
    • These connections can be fragile and must be handled with caution to avoid damage to the cable.
    • Using the tweezers, carefully remove the ribbon cable from the connection port.
  14. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • An additional ribbon cable connector is located on the left side of the motherboard, approximately 1.5 inches from the bottom corner.
    • As stated before, remove the ribbon cable connector carefully and with caution using tweezers.
  15. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • The final connector pin is located in the upper right region of the motherboard, as well as to the right of the previous top middle ribbon pin connection.
    • Using the iFixit opening tool, carefully apply pressure to lift up the connection from the motherboard.
  16. Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 16, Bild 1 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 16, Bild 2 von 3 Toshiba Satellite Click 2 L35W-B3204 Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Now that the motherboard is completely disconnected and all screws have removed, gently apply upward pressure to the bottom of the motherboard using the iFixit opening tool.
    • The motherboard should pop up and able to be taken out by hand.
Abschluss
To reassemble your device, simply follow these instructions in reverse order.
Lexi Lannigan
753 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G4, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G4
6 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 377
