Zum Hauptinhalt wechseln
Toshiba Satellite Click 2 Pro Wifi Card Replacement
Was du brauchst
  1. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 5, Bild 3 von 3
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 6, Bild 2 von 2
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Wifi Card: Schritt 8, Bild 1 von 1
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  9. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 9, Bild 1 von 1
    Kaufen
    • Remove the black and white cables attached using ESD safe tweezers.
  10. Toshiba Satellite Click 2 Pro Wifi Card Replacement: Schritt 10, Bild 1 von 1
    • Remove wifi card.
Abschluss
Paul DeOrsey
893 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-3, Catania Spring 2016
UMASSD-CATANIA-S16S4G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 432
