Was du brauchst
Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
Using a spudger, poke the white tabs in by the battery until you hear a click.
In diesem Schritt verwendetes Werkzeug:Pro Tech Toolkit$59.96
Separate the laptop by sliding a spudger in between the black and silver covers.
Disconnect the Cooling Fan from the Motherboard by gently pulling away on the white tab.
Unscrew the two 3.75mm screws around the Cooling Fan and the copper attachment as shown with the #0 Phillip's Head screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
