Was du brauchst
Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
Using a spudger, poke the white tabs in by the battery until you hear a click.
In diesem Schritt verwendetes Werkzeug:Pro Tech Toolkit$59.96
Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive.
Remove the USB Port Circuit Board.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
