Zum Hauptinhalt wechseln
Toshiba Satellite E45T-A4300 Motherboard Replacement
Was du brauchst
  1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Motherboard Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Pull the hard drive out of the hook and remove it from the device.
  6. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: Schritt 6, Bild 1 von 2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: Schritt 6, Bild 2 von 2
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  7. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently disconnect the fan cable from the device.
  8. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
  9. Toshiba Satellite E45T-A4300 Motherboard Replacement, Heat Sink: Schritt 9, Bild 1 von 1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  10. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 10, Bild 1 von 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 10, Bild 2 von 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
  11. Toshiba Satellite E45T-A4300 Motherboard Replacement, Battery: Schritt 11, Bild 1 von 1
    • Disconnect the battery connector from the motherboard.
  12. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the single screw Phillips #1 screw near the battery.
  13. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 13, Bild 1 von 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the battery from the laptop.
  14. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: Schritt 14, Bild 1 von 2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: Schritt 14, Bild 2 von 2
    • Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
  15. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Pull metal stick holder until it is upright.
  16. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 16, Bild 1 von 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
  17. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 17, Bild 1 von 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 17, Bild 2 von 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 17, Bild 3 von 3
    • Disconnect the six connectors from the device.
    • For the monitor port, pull it from the black tab.
    • For the connection port with the blue strip, lift the white placeholder before pulling the blue strip out of the connection port.
  18. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 18, Bild 1 von 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Pull out 2 plugs out from the wireless network card.
  19. Toshiba Satellite E45T-A4300 Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Remove the motherboard from the device.
Abschluss
James Nguyen
573 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 Mitglied von UMass Dartmouth, Team S1-G4, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 698
