Zum Hauptinhalt wechseln
Toshiba Satellite E45t-B4204 Speaker Replacement
Was du brauchst
  1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: Schritt 1, Bild 1 von 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: Schritt 1, Bild 2 von 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Speaker Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite E45t-B4204 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Speaker Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite E45t-B4204 Speaker Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite E45t-B4204 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: Schritt 4, Bild 2 von 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: Schritt 4, Bild 3 von 3
    • Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the speaker cable from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo has the potential to damage your device.
  6. Toshiba Satellite E45t-B4204 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the speakers.
Abschluss
Emily Bateman
97 Reputation
1 Anleitung geschrieben
IUPUI, Team S3-G3, Wilson Summer 2019 Mitglied von IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 571
