Zum Hauptinhalt wechseln
Toshiba Satellite E45t-B4204 Thermal Paste Replacement
Was du brauchst
  1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: Schritt 1, Bild 1 von 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: Schritt 1, Bild 2 von 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 2, Bild 2 von 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 3, Bild 3 von 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: Schritt 4, Bild 1 von 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: Schritt 4, Bild 2 von 2
    • Locate and remove the four 3 mm screws around the CPU.
    • The CPU is located beneath the copper heatsink.
  5. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the heatsink from the rest of the motherboard and casing.
  6. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: Schritt 6, Bild 2 von 2
    • Now that the heatsink has been removed the CPU is visible. The CPU is the green square with silver metal in the center.
    • Reapply thermal paste above the CPU.
Abschluss
Eduardo
411 Reputation
4 Anleitungen geschrieben
Sam Houston State, Team S17-G4, Blackburne Spring 2018 Mitglied von Sam Houston State, Team S17-G4, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 459
