Einleitung
Use this guide to replace the hard drive in a Toshiba Satellite E45t-B4300.
Was du brauchst
Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
Use the point end of the spudger to lift the the clips that attach the two ribbons to the motherboard.
Pull out the ribbons from the motherboard.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
