Zum Hauptinhalt wechseln
Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement
Was du brauchst
  1. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Bottom Case: Schritt 3, Bild 1 von 1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: Schritt 7, Bild 1 von 3 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: Schritt 7, Bild 2 von 3 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: Schritt 7, Bild 3 von 3
    • Use the point end of the spudger to lift the clips that attach the two ribbons to the motherboard.
    • Pull out the ribbons from the motherboard.
  8. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the 2mm screw with a Phillips #0 screwdriver.
    • Remove the circuit board.
Abschluss
USF Tampa, Team S2-G2, Sullivan Spring 2017 Mitglied von USF Tampa, Team S2-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 302
