Zum Hauptinhalt wechseln
Toshiba Satellite E55t Battery Replacement
Was du brauchst
  1. Toshiba Satellite E55t Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite E55t Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to power off your laptop.
    • Flip the laptop over so that the backside is facing up.
    • Remove the twelve 7.8 mm long Phillips screws securing the back cover.
  2. Toshiba Satellite E55t Battery Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite E55t Battery Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite E55t Battery Replacement: Schritt 2, Bild 3 von 3
    • The back cover is still held in place by plastic clips.
    • Use your fingers to pry the back cover up slightly near one of the display hinges.
    • Insert a plastic opening pick into the gap created between the back cover and the laptop.
    • Run the pick along the perimeter seam, twisting it as you go to release the clips holding the back cover.
  3. Toshiba Satellite E55t Battery Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite E55t Battery Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite E55t Battery Replacement: Schritt 3, Bild 3 von 3
    • Once all of the perimeter clips have been released, grasp the back cover by an edge.
    • Slowly lift the back cover away, wiggling it slightly to help release any remaining clips.
    • Remove the back cover.
    • To reinstall the back cover:
    • Realign the cover onto the laptop and set the cover down in place.
    • Squeeze the edges of the cover against the laptop and press near the center to click the clips back in place.
  4. Toshiba Satellite E55t Battery Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite E55t Battery Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite E55t Battery Replacement: Schritt 4, Bild 3 von 3
    • Peel and remove the black tape holding the battery cable in place.
    • Use your fingers to grasp the battery cable near the connector and carefully pull it out of its socket.
    • Do no pull the cable upwards. The connector slides out parallel to the motherboard.
  5. Toshiba Satellite E55t Battery Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite E55t Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the three 5.7 mm long Phillips screws securing the battery to the laptop.
    • Remove the battery.
Abschluss
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Arthur Shi
254.715 Reputation
529 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.449 Anleitungen geschrieben
2 Kommentare
Great, thanks. Now, how to replace the keyboard? :) From what I can see (opening back), it looks like whole system has to come apart… :(
Richard Ernst - Antwort
Hi Richard!
I’m not sure—I don’t have the laptop anymore. This Youtube video suggests that a keyboard replacement may be a relatively easy fix, but I can’t guarantee that. Good luck and happy fixing!
Arthur Shi -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 263
