Zum Hauptinhalt wechseln
Toshiba Satellite L15W-B1208X Battery Replacement
Was du brauchst
  1. Toshiba Satellite L15W-B1208X Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite L15W-B1208X Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 3, Bild 3 von 3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite L15W-B1208X Battery Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 520
