Zum Hauptinhalt wechseln
Toshiba Satellite L15W-B1303 Touchpad Board Replacement
Was du brauchst
  1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: Schritt 2, Bild 1 von 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: Schritt 2, Bild 2 von 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: Schritt 2, Bild 3 von 3
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
  3. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Touchpad Board: Schritt 3, Bild 1 von 1
    • Remove any pieces of tape securing the board.
    • Using your Phillips #0 screwdriver, remove both screws holding the board in place.
  4. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: Schritt 4, Bild 1 von 1
    • Gently disconnect the cables that link the touchpad board to the rest of the laptop
    • Be careful when doing this. It can be easy to damage the components. If the connector seems stuck, try wiggling it; do not force it off.
  5. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: Schritt 5, Bild 1 von 1
    • Remove the board from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Yanchen Li
121 Reputation
1 Anleitung geschrieben
York University, Team S8-G2, Turner Winter 2020 Mitglied von York University, Team S8-G2, Turner Winter 2020
YORK-TURNER-W20S8G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 291
