Zum Hauptinhalt wechseln
Toshiba Satellite L305D-S5895 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite L305D-S5895 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  4. Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Lift the keyboard up in order to remove the cable.
  5. Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite L305D-S5895 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
Abschluss
Tyler GLick
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 333
