Zum Hauptinhalt wechseln
Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
Was du brauchst
  1. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement, Optical Drive (Disk Drive): Schritt 1, Bild 1 von 1
    • Power off your laptop before beginning disassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: Schritt 2, Bild 2 von 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: Schritt 3, Bild 2 von 2
    • The 5.3 mm Phillips #1 screw boxed in red is located on the right panel that house the RAM on the underside of the computer.
    • Remove the screw securing the drive on the plastic edge.
  4. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: Schritt 4, Bild 1 von 1
    • Use a screwdriver or a metal spludgers to push the metal piece attached to the drive in the direction of the drive opens until the drive pops out of its socket.
  5. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: Schritt 5, Bild 1 von 1
    • Fully remove the drive by pulling it all the way out of its socket.
Abschluss
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 630
