Zum Hauptinhalt wechseln
Toshiba Satellite L305D-S5900 RAM Replacement
Was du brauchst
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L305D-S5900 RAM Replacement: Schritt 2, Bild 2 von 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L305D-S5900 RAM Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L305D-S5900 RAM Replacement: Schritt 3, Bild 3 von 3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Abschluss
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 248
