Zum Hauptinhalt wechseln
Toshiba Satellite L305D-S5900 Storage Drive Replacement
Was du brauchst
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: Schritt 1, Bild 1 von 1
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L305D-S5900 Storage Drive Replacement: Schritt 3, Bild 2 von 2
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
Abschluss
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 345
