Zum Hauptinhalt wechseln
Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement
Was du brauchst
  1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 2, Bild 2 von 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 3, Bild 2 von 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 5, Bild 1 von 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 5, Bild 2 von 2
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 7, Bild 2 von 2
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: Schritt 8, Bild 3 von 3
    • To separate the hard drive from the caddy, unscrew the two screws.
Abschluss
Ricky Baker
217 Reputation
2 Anleitungen geschrieben
Clemson, Team 1-2, Benson Spring 2014 Mitglied von Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 877
