Zum Hauptinhalt wechseln
Toshiba Satellite L455-S5046 Hard-drive Replacement
Was du brauchst
  1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 Hard-drive Replacement, Hard-drive: Schritt 2, Bild 1 von 1
    • Locate the hard drive in the upper right corner on the back of the computer.
    • Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
  3. Toshiba Satellite L455-S5046 Hard-drive Replacement: Schritt 3, Bild 1 von 1
    • Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
Abschluss
Daryl Spurgeon
610 Reputation
6 Anleitungen geschrieben
Oakland University, Team 2-1, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-1, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 287
