Einleitung
The CPU is what makes the computer work. If it is not working properly, the computer may not turn on or work in the way in needs to. This guide will show how to replace the CPU through a series of steps.
Was du brauchst
Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
To remove the hard drive case, first pull the black tab to the right.
Then pull the black tab up to remove the case.
Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
Lift up the plastic panel and carefully disconnect the red and white ports.
Remove the panel
Turn the laptop over so the bottom is facing up
Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
Turn the laptop back over so the motherboard is facing up
Now slide the optical drive out of the computer by gently pulling it to the right
Remove the two Phillips #1 3mm screws from the fan using a Phillips #1 screwdriver.
Remove the six 6mm screws from the motherboard with a #1 phillips screwdriver.
Remove the lone 10mm screw from the motherboard with a phillips #1 screwdriver.
Remove the motherboard with your hands by carefully lifting up and pulling out.
Remove the four Phillips #1 6mm single coil pickup screws from the cooling unit and remove the cooling unit.
Using a flathead screwdriver, undo the lock on the CPU with a half turn in the counterclockwise direction.
Remove the CPU by lifting up on the chip.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
