Zum Hauptinhalt wechseln
Toshiba Satellite L55W-C5256 CPU Heatsink Replacement
Was du brauchst
  1. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 3, Bild 1 von 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 4, Bild 1 von 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, CPU Heatsink: Schritt 7, Bild 1 von 1
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 8, Bild 1 von 1
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 9, Bild 1 von 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 9, Bild 2 von 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: Schritt 9, Bild 3 von 3
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jennifer
777 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 181
