Zum Hauptinhalt wechseln
Toshiba Satellite L55t-B5271 CD Drive Replacement
Was du brauchst
  1. Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271  CD Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271  CD Drive Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: Schritt 3, Bild 3 von 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: Schritt 4, Bild 1 von 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: Schritt 4, Bild 2 von 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: Schritt 5, Bild 1 von 2 Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: Schritt 5, Bild 2 von 2
    • Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
  6. Toshiba Satellite L55t-B5271  CD Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: Schritt 6, Bild 2 von 2
    • Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
Abschluss
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 279
