Zum Hauptinhalt wechseln
Toshiba Satellite L55t-B5271 Screen Replacement
Was du brauchst
  1. Toshiba Satellite L55t-B5271 Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite L55t-B5271 Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite L55t-B5271 Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 3, Bild 3 von 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: Schritt 4, Bild 1 von 3 Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: Schritt 4, Bild 2 von 3 Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Screen Replacement, Screen: Schritt 5, Bild 1 von 3 Toshiba Satellite L55t-B5271 Screen Replacement, Screen: Schritt 5, Bild 2 von 3 Toshiba Satellite L55t-B5271 Screen Replacement, Screen: Schritt 5, Bild 3 von 3
    • Unscrew the four 6mm screws from each of the laptop hinges using a Philips head #00 screwdriver.
  6. Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 6, Bild 3 von 3
    • Disconnect connect the ribbon marked in red.
    • Disconnect all ribbons and cables marked in orange.
  7. Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 7, Bild 1 von 1
    • Flip your laptop back to the front.
    • Lift up the screen cover.
  8. Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 8, Bild 2 von 2
    • Gently pull the screen to disconnect the monitor from the hinges.
  9. Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 9, Bild 1 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 9, Bild 2 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 9, Bild 3 von 3
    • Use the plastic opening tool to pry the plastic covering off of the monitor.
    • Be careful not to break the glass, as this can cause injury.
  10. Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 10, Bild 1 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 10, Bild 2 von 3 Toshiba Satellite L55t-B5271 Screen Replacement: Schritt 10, Bild 3 von 3
    • Remove the four 3mm Phillips head screws with a Phillips #00 screwdriver.
    • Gently remove the screen from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 1,436
