Zum Hauptinhalt wechseln
Toshiba Satellite L55t-B5271 Wireless Card Replacement
Was du brauchst
  1. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 3, Bild 3 von 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: Schritt 4, Bild 1 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: Schritt 4, Bild 2 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 1 von 2 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 2 von 2
    Kaufen
    • Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
  6. Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 6, Bild 3 von 3
    • Remove the tape from the card.
    • Disconnect the wires using the #4 black spudger tool.
  7. Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 7, Bild 1 von 1
    • Remove the 3mm Phillips head screw with a Phillips #00 screwdriver.
  8. Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite L55t-B5271 Wireless Card Replacement: Schritt 8, Bild 2 von 2
    • Pull up on the wireless card and remove it from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Noelle Dulude
480 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 277
