Einleitung
If your computer seems consistently hot, please check the troubleshooting guide to determine if you might have a faulty fan. If find that your fan is clogged, or broken, and not working, this guide will show you how to dismantle the back panel and the other parts of the laptop in order to reach the fan. Keep in mind, this removal process is rather difficult, and should not be attempted alone if you are not comfortable with removing components from your laptop.
Was du brauchst
Flip the laptop upside down. Locate the two latches on both sides of the battery.
Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
Simultaneously slide the latch on the left outwards while pulling the battery towards you.
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
Work your way around the border of the panel, releasing the rest of the clips.
Once all clips are released, lift the cover up and pull towards you.
Slide the hard drive to the left, using the silver tab.
Pull up the silver tab, removing the hard drive from the slot.
Using your fingers, spread the spring tabs holding the top stick of RAM in place.
Once the tabs are spread apart, the stick of RAM will pop up.
Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Spudger$4.99
Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
Remove the first 3mm screw with the Phillips #1 screwdriver.
Remove the next three 3mm screws.
Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
Carefully slide the connector out of the port.
Remove the following screws with a Phillips #1 screwdriver.
Seventeen 5mm screws (recessed)
Three 2mm screws in the battery bay (flush-mounted)
Single 5mm screw does not need removal unless working on the screen
Pry under the top case housing along the perimeter with a plastic opening tool.
Disconnect fan wire from connector with metal Spudger -- the fan can now be removed completely.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
